"LS1 Cheyenne" My project.
![Devil](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_devil.gif)
Originally Posted by JJsSS
dam,why u take all that off the motor?
Instead of the rocker arms I think I should get a cam instead? I was looking at this cam from Thunder R. do I really need new gaskets? The package includes the springs and the cam's got 220/220, 551,551 and 112 LSA. I need the truck as my daily so I can't go all out. Come on guys post some replies.
![Icon Confused](https://www.performancetrucks.net/forums/images/smilies2/icon_confused.gif)
Originally Posted by RICEBURNR
I had to take alot of stuff off b/c since the car is wrecked, all the front end was really pushed back towards the engine. So i needed as much room as possible so most of the accesories had to come off, besides some of them where broken from the crash such as the power steering pump. Hey as far the truck goes, if I use most of the car's fuel system components will I still have to get 97 corvette style fuel rail? And what the heck is VATS and do i really have to get a new wiring harness? Help is apreciate it the sooner I get all the planning straight the sooner I can get this done.
![Driving](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_driving3.gif)
![Bigun2](https://www.performancetrucks.net/forums/images/smilies2/bigun2.gif)
I would get a used cam over the rocker arms, since the new ones are so much money, but thats just me. BIGBOS has a cam for sale in the forced induction forum.
https://ls1tech.com/forums/showthread.php?t=224455
It is slightly better than stock, and would produce some good torque in that engine. But by far the most popular route to go is the TR 224 cashaft. With your manual trans, having that cam on a 112lsa would work well for a daily driver. Rear end gears would probaly need to be swapped to something like a 4.10, since there is a lot of mass to move with a truck, and the T56's ratios are not as deep as truck ratios.
AS far as he fuel system goes, you will need to swap out the pump in the tank for a high pressure unit. The TBI system uses about 15psi, while the LSx series engines use 58 psi. You might be able to use the stock intank pump as a feeder to a high pressure boot pump along the frame rail. The TBI system uses a return line so you could use the 97 fuel rail if you want to keep the TBI return line.
Good luck, and I bet that truck will haul when done.
FormulaZR
09-14-2015 05:23 PM
