ls1 edit 8.1l injector values
Old 07-23-2003, 01:02 AM
Flyer's Avatar
Default Re: ls1 edit 8.1l injector values
My IFR is 5.25 with the Radix tune ...
That help?
Old 07-23-2003, 01:10 AM
hohl's Avatar
Flyer- What are your injector offset values with the 5.25 IFR?
Old 07-23-2003, 01:58 AM
9 Second Club/LS1TECH Sponsor
Speartech's Avatar
Wow! That's a big difference. Flem's came with the 4.17's (33#), and Flyer's came with 5.25's (42#). Is this an upgrade they have done to the kit? Or have you (Flyer) made some changes??
Old 07-23-2003, 07:20 AM
Flem's Avatar
I did some research on the injector flow #'s my burb is a LM7 engine code flex fuel(E85) truck. with stock IFR. of 4.16 the Magnuson tune was 4.17 ??? I'm not sure why but it is but my current tune is 5.05. I'm getting -8 LTft's when the engine is warm so even this is a little big. I can send the edit file to look so you can look @ the offsets.
Old 07-23-2003, 07:24 AM
Flem's Avatar
the I don't know whay there was a .01 didderence between stock anfd the magnuson.
Old 07-23-2003, 07:41 AM
BigTex's Avatar
OK, Flem, the flex injectors are larger than non-flex, so they are the ones that flow 4.16. Where did you get the 5.05 flow number?
Flyer - Would you email me your LS1 file after you installed the Radix. I'll add the info to my sheet. Where in east Texas are you?
Would both of you guys get the part number off the injectors so we can verify we are comparing apples to apples.
Old 07-23-2003, 09:29 AM
LS1TECH Sponsor
Racetronix's Avatar
What would be the interest level in the 42lb (@400KPa) Multec stubby injectors (direct fit) for the GM SUV's? If there is enough interest we can bring some in, flow match them and put them on special.
Jack
Racetronix
Old 07-23-2003, 09:44 AM
BigTex's Avatar
If the price is fair, I think there would be a good number of people wanting them. It would really help to have full flow numbers and offset values for LS1 edit for them. With the stock GM injectors in the 25 pound range, any highly modded vehicle, FI or dry nitrous setup will need injectors.
Old 07-23-2003, 12:40 PM
Flem's Avatar
Big Tex I sent you the ls1 edit file from my truck. I'll check the Pt#'s for the injectors tonight.
Old 07-23-2003, 01:53 PM
LS1TECH Sponsor
Racetronix's Avatar
Keep your eyes open for an announcement on the Racetronix web page in the next week or two.
Quick Reply: ls1 edit 8.1l injector values
