LS1 edit or HP tuner?
Originally Posted by quicksilverado
If you get a custom tune with ls1 edit can you use hptuners? Or will there be a conflict when using hptuners?
Did that answer your question?
Originally Posted by Flyer
HPTuners does just the same as EDIT. It reads what's on the PCM and interprets that into something you can understand (what you see in the tables). What's on the PCM will not change formats rather it's from EDIT or HPT.
I understand that it reads and interprets the data. My concern is if the pcm is tuned with ls1 edit and then you use hptuners to tune again will this cause a problem.
Straight forward ... you won't have any problems with what you're asking about. Howver, if you ARE doing a email tune and the tuner is using EDIT, you can't use HPT to upload the file that was made with EDIT.
