LS1 fan swap question
Old 12-11-2002, 01:23 PM
14 Second Truck Club
Default LS1 fan swap question
What all is involved in this? Is it expensive? Is there noticable power gains? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old 12-11-2002, 02:35 PM
MOOBIES Moderator
Scream's Avatar
Default Re: LS1 fan swap question
Not too expensive...I would say easily less than $150...I got a steal on my fans and got away for under $125.
Check out www.tacreationsusa.com. They're fairly reasonable on their prices. I had a friend do the install, but it looked fairly straight-forward. Do a search in this forum for electric fans or LT1 fans and you should have more info than you could possibly ever use! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I noticed a little SOTP difference. The truck runs cool even with the A/C on in the summer!
Good luck...a worthwhile mod!
<small>[ December 11, 2002, 02:36 PM: Message edited by: Scream ]</small>
Old 12-11-2002, 08:30 PM
What is involved in the swap? Belts, switchs, wiring, etc.
Old 12-11-2002, 10:04 PM
GREGGO's Avatar
Got my fans for $75. You can use LT1 or LS1 fans and they will be plenty for the designed use of a 1500 series truck. There are many ways of wiring them up. Some use "always on w/ign", "one on w/ign, one switched (like me)", AC relay on, t-stat switch, etc...But always use a relay setup for wiring. Let us know how you want to run them and we can help you out if you need it.
Old 12-11-2002, 10:55 PM
Moderator / Sponsor
oxidizr's Avatar
1.) remove shroud and fan blade/clutch assembly.
2.) mount electric fan assmebly
3.) wire fans to run as prefered (see fast4.8's post)
Not too dificult and requires no alteration of pullies or belts.
Old 12-11-2002, 11:28 PM
graygmc's Avatar
yea i think e-fans are the best over-all mod to buy.
1.cheap
2.frees up engine space
3.engine runs cooler
4.little bit more HP
5.sounds cool!
<small>[ December 11, 2002, 11:29 PM: Message edited by: graygmc ]</small>
Old 12-12-2002, 12:06 AM
What is involved in the switch set-up?
Old 12-12-2002, 01:13 AM
im about to do the same thing
i want to have the fans turn on at a set temp like stock but have a manual override to turn them on and off. what do you guys think or would you reccomend a different approach?
Old 12-12-2002, 07:09 AM
ArticGMC's Avatar
I have a set of LS1 fans and was wondering what I would need to setup the fans to come on at 175 and have a manual override switch just incase they don't come on at the desired temp.
Thanks,
Lar
Old 12-12-2002, 08:17 AM
L82gofast's Avatar
Check out www.permacool.com and in the online catalog section click on electric fan accessories. they have a few different wiring kits that will fit all of the above applications.
Quick Reply: LS1 fan swap question
