ls1 fan wiring schematic
Does anyone know how to wire ls1 fans. i want to use relays and all. i saw the nelson harness and i wasnt impressed. I was thinking I could build my own. would anyone have a schematic and what types of relays would be needed. Any help would be apreciated. later
Yes, they work. I have had both setups in the truck. I currently run the 3relay setup. Check my cardomain site (in sig) for a brief writeup and pics.
Just a note: I'm not using LS1 fans, but the concept is still the same.
Fan schematic
Awesome fan schematic, very helpful and will probably be cheaper than Nelson. I was definetily wanting to build my own but was going to have both fans come on at once. I like this way, looks and sounds way more stock and professional. What temp should i tell the fans to come on?
Thats how mine are set up. I have teh schematic somewhere but dont have a scanner. I have a few harnesses already made though. If you wnat one 2 or 3 relay, PM me. I just need to trim some wires and solder the fan connectors on and wire loom em.
