LS1 fans from GM
Old 08-04-2004, 10:26 PM
Mr. Sandog's Avatar
So, let's say I get these '05 fans........how will I control them?
Old 08-04-2004, 10:31 PM
what a rush!
moregrip's Avatar
and what size radiator will they fit?
Old 08-05-2004, 03:53 AM
MacADaYear's Avatar
Probly the same way more people are controling the LS1 and flex-a-lite fans.
Old 08-05-2004, 07:42 AM
Sport Side's Avatar
in non-smartass form that would probably mean by the pcm.
Old 08-05-2004, 07:55 AM
I might have to check into these....If they flow more CFM, I might need to get a set over my LT1 fans. So, could I run these off my Flex-a-lite Adj. Thermostat?
Old 08-05-2004, 08:15 AM
zippy's Avatar
i would think you'd want to run a relay to both and use a fan controler to run them. that picture is for the half ton 05', but i'm not sure all which models it fits yet. working on it.
Old 08-05-2004, 09:24 AM
marc_w's Avatar
Naked - I'd recommend the DCC fan controller if you're in the market for a bran new unit.
Guys - Anyone know how the fans operate? Does the VCM control each fan individually like the LS1 motors, or is it more or less wired parallel like the Flex setups?
Old 08-05-2004, 11:57 AM
Mr. Sandog's Avatar
Cool, look forward to when you find out, Zip.
Old 08-05-2004, 12:00 PM
what a rush!
moregrip's Avatar
what size radiators do these new electric fans fit?
Old 08-05-2004, 01:25 PM
MacADaYear's Avatar
Thats one way. Or you could use the flex-a-lite VSC. And now there is a new DCC controler that alot of members are having great lucky with
Quick Reply: LS1 fans from GM
