LS1 fans from GM
Originally Posted by Naked AV
So, let's say I get these '05 fans........how will I control them?
Originally Posted by MacADaYear
Probly the same way more people are controling the LS1 and flex-a-lite fans.
I might have to check into these....If they flow more CFM, I might need to get a set over my LT1 fans. So, could I run these off my Flex-a-lite Adj. Thermostat?
i would think you'd want to run a relay to both and use a fan controler to run them. that picture is for the half ton 05', but i'm not sure all which models it fits yet. working on it.
Naked - I'd recommend the DCC fan controller if you're in the market for a bran new unit.
Guys - Anyone know how the fans operate? Does the VCM control each fan individually like the LS1 motors, or is it more or less wired parallel like the Flex setups?
Originally Posted by SportSide 5.3
in non-smartass form that would probably mean by the pcm.
