LS1 Fans installed...NO WORKY!
FarmerBeau,
Don't feel bad, My fans worked great for 2 months and than one day they would not come on when the pcm told them to but would work when I turned the ac on. Switch around the relays traying to figure it out and now I have no fans pcm or ac. I am starting to think like you (snaffu)
Mark
Mark
Sexy Party Mod
I know man. I thought it would be plug and play! I should have known it wouldnt be that easy from the start. my cam install went fine and everything...no it didnt. I had tapping sounds and i stripped two spark plug bungs. SNAFU is right
PT's Slowest Truck
Originally Posted by FarmerBeau
HOW? is there a way to check them?
PT's Slowest Truck
Ok, give 12v to pin 86 and ground pin 85 (or vice versa, doesn't make a difference)
After doing so, you should have a complete circuit from pin 87 to pin 30 which will read as low resistance on an ohmeter
For more electrical info, this website is great: the 12volt.com
Moderately Differentiated
Every time i want to do something cool to my truck it always screws up and doesnt go as planned. I will start calling my truck "project SNAFU"
listen to budhayes3, he seems to have a handle on the install. Stay simple when it comes to trouble shooting...get those fans to turn on with you giving them straight battery power and no internal switching.
Sexy Party Mod
Thank you Budhayes3. I checked the relays and found a dud and replaced it worked. but not all of the way. Im gonna call Allen and see what he says. One doesnt work on the harness but worked whenever i put power directly to it. The other only works when i fire up the truck(turns on then turns off) or when the AC is on. Im really stumped at all of this. I really dont know what to do now. Only one works only when the ac is on.
