LS1 fans with nelson harness......helpppppp
#51
The Nelson harness is wired like this:
My wiring harness did not work 100% when I installed it either. When the relays were plugged into relay holder it had pushed out the lug for the PCM input. Worked when I first tested it during the install then didn't when I got finished. No biggie I found it quickly. Looks like there are some quality control issues with these harnesses.
#53
Originally Posted by 02denali
as with any other company or product there are going to be ones that dont work. he is only human as we are. and his relays dont use two pcm pin outs.
You are right the wiring diagram above shows 2 pcm outputs. #17 being a 12V AC command out. It is not correct. The rest is representative. I think I have the other/correct one that I will put up if I can find it.
Wrecker 426
09-30-2015 09:39 PM
FormulaZR
09-14-2015 05:23 PM
