LS1 heads????
Old 02-12-2006 | 03:06 PM
EvilChevy's Avatar
Default LS1 heads????
I am considering a set of LS1 heads for my 2000 Chevy ex/cab w/4.8 litre. I'm curious if they will flow better than my stockers...
Old 02-12-2006 | 08:53 PM
TarheelZ's Avatar
I think it depends on your definition of 'better'. They'll flow MORE, but they'll also lower your compression. Are you planning to go FI?
Old 02-12-2006 | 09:12 PM
Nikon02's Avatar
if you check other threads i believe that It will lower your compression and almost overflow for the 5.3 let alone the 4.8. I do not know of any heads they recomend for the 4.8 though.
Old 02-12-2006 | 09:24 PM
v8
17,16,15,14,13,12,11 Drvr
If you get the ls1 5.7 heads the valves will be so close to small bore of the 4.8 and 5.3 that you could burn a valve quick, but if you do decide to get them make sure you get the 5.7 head gaskets.
axekick
09-07-2015 07:01 PM
nrmskate
08-11-2015 02:44 PM
RONIN LSX
08-11-2015 12:03 AM
Denali08
08-09-2015 04:34 PM
Black-Syde
07-06-2015 02:12 PM
Quick Reply: LS1 heads????
