LS1 Heads
LS1 Heads
I bought the LS1 Dart 205 heads and was wanting ya'lls opinion on getting them CNC'D or not. They'er gonig on a 5.3 with all of the bolt-ons as possible. I will be doing the LS6 intake swap also. I'm going to install a cam, rockers..........the whole gammit!
Thanks fellows!!!
James
Thanks fellows!!!
James
Nice choice, what cam are you going with? I thought the DARTs were only offered in a 225, they are gonna perform great in the as cast shape, if your machinist thinks you can gain anything from a valve job I would definately do that.
It depends on the cam as to whether or not ID port em anything over 222 duration and Id go with a small stage 1 job if your going for a bigger cam around 230 Id go with a stage 2 but I wouldnt remove alot of material. Id be concerned more with velocity than peak flow numbers, I think the smaller intake runners help with a heavier vehicle and an NA setup.
I'm going with the comp 222/224,.566/.568,112 sep with the 1.75 rockers. I think these are the specs. I was going to go with the 224/226 dur but this might be too big. The heads already have an 3 angle valve jod on them I believe in the as cast......I will be putting in a 34 or 36 stall also. Sure, I agree with the smaller ports will help. I'm just pondering with this...can't make up my mind!!!
