LS1 heads on a 4.8
Old 12-30-2005 | 10:23 AM
Richard@WCCH's Avatar
FormerVendor
Originally Posted by Formulized94
Richard,
Thank you for that, there are some people that will argue until they are blue in the face about that.
I have a question on your heads though, do you see much of a pickup going from the 2.00" valve compared to the 2.02 on the ls1 heads?
Ryan
Yes, there is some advantage to going with the slightly larger valve. The valve "curtain area" is increased without paying a big loss in shrouding. The bore size relative to the valve size is important.
Richard
Old 01-01-2006 | 09:52 PM
Mighty Wings's Avatar
Originally Posted by ktmrider
They flow better than the LS1 heads on the exhaust side due to the "D" shaped port. They will also not drop as much compression due to the chamber size ( 65cc vs 68cc ).
Using the intake will cost you a ton of low end power over the truck models, plus you would need to install the LS1/LS6 belt drive system ( the car intakes are lower and the TB interferes with the water pump outlet ). The truck intake shows as good or better at all RPM's below 5000.
The cam would be a nice combo with the heads as long as you get the CR up a tad.
I'll probably get the ls6 heads milled, that should help. How much torque do you think I'd lose if I use the z06 intake? Would the horsepower gains even things out at the track?
HectorM52
08-18-2015 01:40 PM
nrmskate
08-11-2015 03:44 PM
Denali08
08-09-2015 05:34 PM
JordanH
08-08-2015 08:59 PM
Black-Syde
07-06-2015 03:12 PM
