ls1 hot cam installed
well i put the ls1 hot cam in this last weekend and boy was it fun it fired right up on the first try........ but now it is a real dog its like driving a terd i dont know wtf i need to get it tuned!!!!!!!!! i have ls1 edit already but dont have a clue where to start drove it like 50 miles figuring the comp would learn a little did learn some but not enough no clue where to start.... i already looked in the ls1edit.com flash files for a tune i lwill look at those to get a idea but if any one could point me in the right direction i would greatly apreacate it btw its a 2000 4.8 auto and it sounds really mean at idle but cant back it up my guess is it runs like a 20 sec 1/4 mile oh let me get this straight you put a cam in to lose hp right????????
thanks for the help
thanks for the help
Originally Posted by nativetexan
That is a lot of cam for a 4.8. You definitely will need a tune and a stall.
Oh yea you will!!!!!!! A loss of some low end comes with the territiry with a cam like that. Especially in a motor smaller than an LS1. You lose some low end to gain mid and top end power. Thus where a higher stall verter comes into play. To make up for the loss of low end.
Not trying to hijack, but as stated earlier I've been thinking of this cam for a little while. I know I'd need a tune and have figured that in with the price, but I wouldn't necessarily need a stall unless I wanted to take full advantage of the cam, correct?
I have this cam, and yes it will be a pain (my experience at least) to work with. I need to still iron out a few tuning issues. For the time being, just to get yourself from point A to point B, flip the "set idle screw" on your TB around so you can access it from the top. Then crack the blade open a little bit so your motor can idle better.
I didnt lose any HP or low end torque.. if anything I gained low-end torque. I do have a 3000 stall though.
I had some tuning issues too. I have a nelson tune, and it took a few iterations for him to get the idle issue down. I didn't notice a loss in low or high end. I have a stall though. It has a helluva lot more power all over the rpm range. Its a good bang for the buck cam kit. I think I have a lot of power still left on the table though, because I don't have headers to take advantage of the long exhaust duration.
You might consider a nelson tune, and use edit from there. But dude, come on....20sec 1/4mi....that's terrible, even for Tucson. You shouldn't run that stock, unless your truck is f'd up to begin with. Anyway, good luck!
