LS1 Intake on 5.3 with returnless fuel system
#21
Originally Posted by DozerDan
Will these fit LS1 injectors?
It says they replace GM12085491 which is the connectors for the LS1 injectors...Don't look right though
#23
mine are nasty performance fuel rails..i got mine from a buddy in town..his bro wrecked his firehawk and i got the wiring harness from it..the wires to the injectors are all color coded and ls1 harness has the same colors plus numbers..easy to hook up..by the way you could have put a better pic of my engine in the first pic..
#25
OK, gathering parts for the swap. Intake is on the way, Going to use stock LS1 injectors, Summit fittings and lines, some kind of billet fuel rails , looks like I can use my stock water pump with slight modifacation.
Do I need a car map sensor? What relocation brackets? Different Accessories?
EDIT: Just need idler relocate bracket and can keep accesories
Anything else???
Anything else???
#29
I think its this one
call Jonaton at thunder racing he will know for sure
142-54028 F.A.S.T. LSX 3/8 to -6AN Fuel System Conversion Fitting (This is a 3/8 push connect coupling for a OEM fuel line to convert it to a -6AN Male fuel fitting for use in conjunction with the FAST Fuel Rails)
#30
