Ls1 Intake swap and keep your truck accessories
Very easy.. since the fbody water pump and the truck water pump have the same casing (except for the inlet pipe) and shaft, just take the pulley off your truck water pump and press it on the fbody water pump..belts line up perfectly, i havent set the intake on this yet, but i think it should work..
Originally Posted by Quik
good if it works out for you that way
how about the clearence between the pulley and TB?
17,16,15,14,13,12,11 Drvr
umm, your idler pulley won't work in the stock location, you will also have to cut the bracket its held onto, you will either need to make a new bracket under the alternator or get the speartech one. good luck either way.
