ls1 intake vs truck intake. thoughts
#31
Since a picture is worth a thousand numbers...
I took the liberty of putting the data from the TPIS/Sweet Thunder mag intake test Erik linked to earlier into excel go get a better visual comparison of the intakes tested. Take a look at the graphs and tell me which intake you would rather have. I only plotted the GM manifolds(ls1/2/6) this round as those were the only ones I was imediately interested in. I will share the entire excel file once I get all the data put into it. I think I have made up my mind on what I want to do, just got to start saving the funds to do it, although I think I can do it fairly cheap, considering.
#33
Originally Posted by TurboBerserker
The TPIS spyder (identical to the Vic Jr.) came out on top of the FAST 90 in CHP's test. Here's a link to the article. They don't explicitly say so, but it looks like no elbow.
Interstingly enough, if you look at a useable max RPM for most trucks, say 6400 rpm, the LS2 car intake makes the best numbers.
#35
That LS2 and 90 dont look too bad, huh?
#36
I really dont think all the problems with the truck intake discussed in this thread are an issue with FI as the manifold is pressurized and dosnt flow in the same fashion as in a NA application.
Anyone else have an opinion on this?
intake is pressurized
voids are filled and air flows to the point of least resistance
Thats why parish makes ungodly #s through the truck intake, but...
this reminds me of another thread
The results fom the 90 and radix
comparing this to the 90mm on the radix is different,
because its on the pull side ,so to speak, therefore making the blower work
less
If the radix was blowing into the TB I dont think they would have seen the gains like they did
my opinion would be small gains when compared to an NA setup
but who knows, sometimes opinions aint worth a damn
#39
I did it and noticed some gains especially up top. I am running a LS1 though. Do I have any proven numbers? Im afraid not! I think I paid $30 for it and when I get around to putting a LS6 intake on it will be an easy swap!
#40
