LS1/LS6 intake on truck engine
#126
ok here it is problem solved
2007 L92 with GMPP L76 intake and nick williams 90mm drive by cable throttle.
all i needed to do was clear the water pump wich i did by grinding off some of the water pump neck and a tiny little bit of the NW 90mm throttle linkage.
now all i need is the pulley relocater and wuala you got it done.
heres the cellphone pics lol
oh if your gonna go drive by wire you will also need to nutch the alternator braket i didnt get a chance to do yet. you need to notch it so the tps, & aic sensor could fit..
#129
Man I hate to be the one to tell you this but no. I hope you didn't go out and buy that throttle body not knowing this. The ECM doesn't have parameters to allow a drive by cable.
#130
theres gotta be a way.
its out here somewhere i found a file on holden crazzy
