LS1/LS6 intake on truck engine
Old 01-23-2007, 04:51 PM
  #51
ZR1 DREAMING's Avatar
Originally Posted by bluecajun5.3
or you can swap the truck wp for a car style one.
press off the truck pully and press it on the car wp.
, I swear there's 100,000 threads about this floating around
Old 01-23-2007, 06:17 PM
  #52
2004SSS's Avatar
could someone tell me if the fuel rails on a car intake are differnet from a truck intake? if so are they interchangeable?
Old 01-23-2007, 07:29 PM
  #53
closet red neck's Avatar
i'll be doing the swap this month or next.
i'm drive by wire.
parts are in sig
ME too!!!!! I can't wait for my heads to get out of the shop!!!
James
Old 01-23-2007, 07:33 PM
  #54
Originally Posted by Z06 DREAMING
Yes and yes. It also comes with fuel rails with the right pt#. That is what I have.
And an FYI for those of you saying the LS6 swap is not worth it unless you spin past 6000rpm.... In any cammed truck the stock intake stops power rediculously @ around 5200rpm, an LS6 does not lose power below that and only gains more above that. All this is due to the prior stated plenum volume increase. I would not waste my time with an LS1 intake.
It was a must for me to ditch the stock intake, when I first got down the track with my old H/C set-up my truck fell flat on it's face 2/3 to 3/4 of the way down the 1320. My mph was only 94! when it should have been easily over 100 It was actually rather embarassing.
I went with the vic jr. for the purpose of my new set-up being spun to 7200rpm. And to all together avoid the leaning issue which is still affected with an LS6 intake and the FAST intakes.
It sure is good to see someone else thinks like me!! Also to add, just because you put an LS6 intake on doesn't mean that you have to spin it to 6800+ rpm either.
James
Old 01-23-2007, 07:34 PM
  #55
that's the biggest load of i ever heard of.
i'll be proving this wrong! FYI
I'm with you Lance.
James
Old 01-23-2007, 11:33 PM
  #56
11 Second Truck Club
bluecajun5.3's Avatar
yes and yes
1. the truck rail cross over tube sits a lot higher b/c the intake is taller than a car style.
2. if using a truck rail, you need 5/8" spacers between the rail and the intake. also the truck injectors are different from the cars but they can be modified to work.
3. you can also use the car fuel rails for a cleaner setup and if you want to upgrade to bigger car style injectors.
4. 99-03 trucks have a return style fuel system (2 lines on the intake)
04 on up have a returnless fuel system (1 line on the intake)
Old 01-23-2007, 11:38 PM
  #57
onebadrubi's Avatar
Is it possible for a mod to weed out some of these post? This thread is IMO the best intake swap thread just gettin to be so many pages. Are their some post we could weed out?
I hope bluecajun does a good write up with pics.
Old 01-23-2007, 11:44 PM
  #58
yeah,
i'll be sure to do a thourough write up w/ pics.
i might start tearing it down tomorrow after i finish my torque converter install.
Old 01-24-2007, 12:04 AM
  #59
Did you guys use the factory truck coolant tubes? For some reason my LS1 manifold won't fit right with the tube in place. I fiddled with it for a bit and haven't had a chance to go back and mess with it some more but it sits up high on the passenger side.
Old 01-24-2007, 05:29 AM
  #60
tdrumm's Avatar
yeah,
Let's get a move on! There's a lot of eyes on this swap.
Quick Reply: LS1/LS6 intake on truck engine
