Ls1 Or Ls6 Whick Is It.
The 216/220 Comp cam is a mild cam for a 5.7.I would go with Comp 918 springs with titanium retainers and the XE-R version of that cam.The truck would be a beast,but totally drivable.
The titanium retainers are overated IMO. The behive springs have tiny retainers anyway. I twist mine to 6500 with no valve float. I'd go with the 216/220 at least if not bigger. I like a lot of cam. Oh and the stock hp on that motor is 350. 385 sounds about right for the tq.
The LS6 valvesprings will work as will the LS6 cam,but the LS1 heads won't flow as much as a set of LS6 heads.You will need to check your push rod lengths because the LS6 cam has a bigger base circle on the 02 or later cam.
The lobe on a LS6 is actually larger.To increase lift and duration you can grind materal from the backside reducing the base circle or you can use a bigger lobe like GM did with the LS6 cam.
PT's Slowest Truck
