LS1 Parts List
14 Second Truck Club
LS1 Parts List
Here is a list of most of the parts I plan on getting for the LS1. Please let me know if some of these parts are unnecessary like the studs or if you have parts for cheap
- ASP Crank Pulley (Will the one off my truck work?)
- Comp Cams Adj. Timing Set
- Comp Cams Lifters
- Comp Cams 918 springs
- Comp Cams Titanium Retainers
- Comp Cams Roller Rockers (1.75)
- Comp Cams Rocker Arm Studs
- Comp Cams Pushrod Guide
- TR Hardened Pushrods
- ARP Connecting Rod Bolts
- ARP Main Stud Kit
- ARP Head Stud Kit
- Valve Cover Spacers
- FelPro Head Gaskets (a little thicker than stock)
- LS6 Oil Pump
- Custom Cam (thinking about the Vinci 216/224 – 113LSA or a custom FMS cam)
These are some parts that I will be getting from the dealership:
-Cam Bearings
-Main Bearings
-Rod Bearings
I’ll also be getting some piston rings from twobit.
- Comp Cams Lifters
- ARP Main Stud Kit
- ARP Head Stud Kit
- LS6 Oil Pump
-Cam Bearings
-Main Bearings
-Rod Bearings
I wouldn't limit yourself to just CC on the valve train stuff, you can save a good chunk of money by getting a different chain and rockers. I would bet the rockers will come with new bolts/studs. The valve cover spacers may not be needed. You may need to go with a stock size rocker arm depending on your cam. All else looks good.
5.3Caprice
11-07-2015 08:56 PM
