LS1 swap for '03 with DBW TB
Old 02-15-2007 | 09:32 PM
Silver-Dollar's Avatar
Default LS1 swap for '03 with DBW TB
Has anyone done one? Local guy has a 2000 LS1 with 60k for $1k.
"I will include:
LS1 241 casting heads with Z06 springs
Rollmaster Timing set (less than 5k miles)
Ported LS6 oil pump (less than 5k miles)
FAST Billet Fuel rails, AN fittings, braided lines, caps, and factory style quick disconnnect to connect to factory fuel lines(less than 5k miles)
Smooth Bellows
Factory cast iron manifolds
Stock intake
Stock camshaft
Factory LS1 intake
Factory Thottle Body
Valley cover
Front timing cover
Motor has NEW oil pan gasket, front cover gasket, rear cover gasket
Motor maintained about 45-50psi of oil pressure at idle
$1,000"
Old 02-15-2007 | 09:39 PM
v8
17,16,15,14,13,12,11 Drvr
it will be the same as what motor you have in the truck now. just move all your Acc. off truck motor and put on new ls1. good luck.
Old 02-15-2007 | 10:23 PM
Zick's Avatar
Yup, no big deal. I had a 98' LS1 in my 03' before I put the LQ9 in it. Just use all the truck stuff and it's easy as pie.
Old 02-16-2007 | 08:19 AM
Already sold. crap. However, there is a '05 escalade motor with computer and fuse box in paper for $1200. Need to call to which motor it is.
Old 02-16-2007 | 08:25 AM
Called about it. It was sold also. LQ9 with 4k miles on it.
Old 02-16-2007 | 06:45 PM
xlcooplx's Avatar
just curious man..where are you finding these? im around myrtle but all of the local yards here act like they dont want to part with them? im looking to do a swap in the fall. thanks again!
Old 02-16-2007 | 09:53 PM
fastgm.com for ls1 - newpaper for lq9, but its rare
Bluecollar Hotrods
06-11-2024 11:37 PM
Denali08
08-09-2015 04:34 PM
creekrat
08-02-2015 01:27 AM
Black-Syde
07-06-2015 02:12 PM
Quick Reply: LS1 swap for '03 with DBW TB
