ls1 water pump
Banned
ls1 water pump
when i go to install the electric fans rather than pull the fan off the stock water pump would it be just as easy to put on an ls1 water pump without the fan assembly on it, since i'm doing the cam swap i figured i'd do it all at the same time to minimize coolant loss etc. anyone have any feedback on this, or will it even work?
Matt
Matt
Banned
Re: ls1 water pump
what difference will not having those threads there make? if any at all? by the way...will fbody 02 simmulators work on an 02 truck?
Matt
Matt
Re: ls1 water pump
if you have an electric fan and dont want to use the stock fan clutch assy. then it wont matter on whickh water pump you use.
as for the o2 sims, they will work but you will have to splice the connectors with the truck ones.
SlvrSierra4.8
10-01-2015 09:39 PM
rednekferlife101
09-14-2015 05:27 PM
mr03silverado
09-02-2015 11:43 PM
