LS2 Heads and Intake on 5.3
for the car intake you will have to make some modifications to your accessory drive. the truck intake will bolt right up. a few differences in evap hose routing and you need a torquerush adapter to use the 90mm t-body unless you are cable driven. but a relatively easy swap. i had the ls2 heads on my 5.3 and am using a tbss intake on my current 6.0.
