ls2 intake/throttle body swap on a lq4. Will the Throttle body work?
Old 03-07-2013 | 12:01 AM
darkostoj's Avatar
Default ls2 intake/throttle body swap on a lq4. Will the Throttle body work?
I want to run a car intake and I got a ls2 intake and throttle body and was wondering if the ls2 throttle body is compatible with the factory lq4 setup?
Old 03-07-2013 | 01:19 AM
Mangled03gmc's Avatar
Baltimore Whore
Yes it will bolt on. You will need a X link controller for the TB plug to the truck plug, some fuel line work, injectors, adapters.
Old 03-07-2013 | 07:37 AM
darkostoj's Avatar
I wanted to keep everything OEM. Is there a way to do it without the xlink?
Old 03-07-2013 | 09:15 AM
luisdavid11's Avatar
i think i read somewhere here some guy just rewired the TB plug onto a nnbs TB plug. I looked at some diagrams of them and it seems doable.
Old 03-07-2013 | 09:21 AM
darkostoj's Avatar
isnt there something different about how the throttle body functions are processed in the TAC module?
Old 03-07-2013 | 09:32 AM
Don't think so. All i do know is that the NBS TB has 2 sets of "LO REF" wires and 2 sets of "5V Ref" wires. And the NNBS, in your case ls2, has only 1 set of each. It's somewhere in this forum I read that a guy did it, he just left those 2 unspliced or just spliced em in with the others and it worked. I can't find the thread tho..
Old 03-07-2013 | 10:24 AM
darkostoj's Avatar
what about using the corvette ls2 TAC and Gas pedal?
Old 03-07-2013 | 10:26 AM
yeah that'll fix your TB plug issue, but how will that LS2 tac communicate with the lq4 pcm? Unless the plugs are the same..? which i doubt
OHsixLS3
12-27-2016 10:30 AM
jdb11386
12-03-2015 10:34 PM
Slammed96
07-27-2015 08:22 AM
GreyChevy
07-07-2015 09:57 PM
Gadgetized
07-07-2015 05:40 PM
