LS6 cam in a 5.3?
LS6 cam in a 5.3?
hi guys. i posted here a while back about an LS6 that i was going to put in my 99 silverado. I've decided putting off on the engine install for at least another 2 years because i simply don't feel like doing it right now. (i have to do some work to the block and maybe might even do a stroker kit in it.) anyways, i was wondering if the LS6 cam would be a good choice for my truck to get more power, since i have the all the parts i need (cam, valve springs etc.) i can just steal them out of the engine since i'm not doing anything with it right now. or should i go with an aftermarket cam? if so which one. i don't really want to lose torque but i want to gain hp on the higher rpms. my main mods are intake, shorty headers, exhaust, and westers 93 hot tune PCM.
With my cam and tune it was alright.... didn't have great low end but wasn't bad. With the stall it is pretty nice..... or should I say would be with traction.
But as crazycutter said..... just advance that bad boy.
[/QUOTE]why not just put the heads cam and all on the 5.3 if you don't want to swap up now.[QUOTE]
I was going to put the heads on also but i heard i will loose a point of compression and don't know if that would be worth it. what do you guys think? will the heads make that much of a difference to make up for the lower compression ratio?
Originally Posted by B3Enterprise
check out october 2004 issue of car craft. lingenfelter got a 5.3 to 413 crankshaft horsepower with only a cam 9(229/242 on 114.5)and headers. hope it helps some. pretty good article.
(again)
yeah i saw that artical. i dont think thats a good cam for MY truck. its all high rpm power and they lost a lot of torque down low. so whats the opinions on putting the heads on also? oh also, sorry to be a pain will i be able to run the LS6 cam with the stock converter until i get a higher stall comverter?
07NBSChevy
20
07-08-2015 07:27 PM
