Ls6 cam in a 5.3????
What year Cam is it? What year is your truck? Any other mods you have? I know the 01 Ls6 cam is more recommended than the 02 Ls6 cam! But the 6.0 Truck intake is no different than the 4.8,5.3's! What size are the injectors you runin? They shouldnt make any difference in power.
The only thing that should give you some extra ponies is the cam! Not a whole bunch but you should notice a slight differennce!
ive heard upwards to 50 h/p from that cam, a good free-flowing exhaust system & a nice air intake system. I've also been told that the intake from an SSR (6.0L truck style LS-2) has a better throttle body mounting position for great flow etc. etc. etc. as well as room for a much larger throttle body.
Good luck with everything!
fuel injectors
This motor is in my 72 2wd blazer and has no emissions equipment. I put in all the running gear out of a 01 chevy truck including the disc brake rear end. Hopefully it will be nice. I plan on adding a turbo down the road. I also was wondering if the 2005 H.0 6.0 has bigger fuel injectors???
07NBSChevy
20
07-08-2015 07:27 PM
