ls6 cam in my tahoe
#21
http://www.summitracing.com/parts/tfs-30602001
Done. New cam shipped for $288. You will lose a little bit on the bottom. However, the power will hit hard around 2500rpm and pull hard all the way to 5500rpm. You won't even notice the cam at all with a trailblazer stall. You will gain 60+rwhp and sacrifice basically nothing.
#26
it has some chop to it at idle..if you know about cams youll know its there by the sound but im impessed with the cam my i ddnt notice any drop in MPG so thats always a plus and a good gain in mid to hi end
#27
10 Second Club
I was considering an 02'-04' Z06 cam, but keep hearing that it will make my LQ4 a slug below 3000 RPM.
#28
if by z06 you mean the ls6 than from what i came up with you can use them but its too close to its max lift..what they told me was that if i was gonna do it with that close of a lift to just do it right the first time and got PAC 1218 springs
#29
The LS6 springs will cut it, but the others are safer.
Glad you're loving the cam too. I love the really subtle chop at idle. Very clean and powerful. Hard to ignore by your friends I'm sure. Add a mild converter and it'll rip from start to finish.
#30
this. You're learning quick.
