ls6 cam in my truck.
Old 10-16-2003, 04:16 PM
Ryan23silverado's Avatar
Default Re: ls6 cam in my truck.
I have Many thoughts about the differences of these two cams, but Matt I would like to know why you think '02 over '01 cam?..just for new ideas sake
EDIT: Thank you whiteZ71 for that link. I would agree that the design engineer of the cams knows what the cam specs are I now believe what they have listed at Scoogin Dickey Chevrolet and GMpartsdirect.com to be incorrect and headache-causing information that they need to fix.
Old 10-16-2003, 05:31 PM
11 Second Club
Grey Silver's Avatar
I've always heard that the 01 is a better choice for our trucks and there's a good reason for that.The 01 has a ls of 116 and the 02 is 117.5. I still run the 01 ls6 cam in my truck. It's one of the best mods I've done. It made over 30 hp to the rear wheels.
Old 10-17-2003, 12:05 AM
FILE's Avatar
Was this 30rwhp with tuning?
Old 10-17-2003, 07:44 AM
What else is needed for the '01 cam swap? Would it be ok with a blower down the road?
Old 10-17-2003, 08:11 AM
whitez71's Avatar
Has any body seen this comp cam. Looks like it would be another good cam. According to comp it is a replacement for the LS6 cam.
54-424-11
Great LS6 replacement. Wide power band.
212/218 .558/.563 LSA 115
RPM Range 1400-6700
Old 10-17-2003, 11:22 AM
hohl's Avatar
Here are some dyno numbers for a Comp 212/218 .558/.563 114lsa dyno results w/ stock heads
Old 10-17-2003, 02:57 PM
13 Second Truck Club
Location: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Ryan, for you boosted application go with the 02 LS6 cam, you wont be dissapointed.
Funny, I have one of those!
Too bad it isn't in your truck
Old 10-18-2003, 12:57 AM
FILE's Avatar
54-424-11
RPM Range 1400-6700
Where did you find this cam for sale? I can't seem to find at Tbyrne or Thunder.
Old 10-18-2003, 01:03 AM
hohl's Avatar
You can find it on the Comp Web site or you can call any of the sponsors who order cams from Comp. I ordered my custom grind from Trevor at Texas Speed and Performance.
Old 10-18-2003, 06:39 AM
11 Second Truck Club
L-EATER's Avatar
Shark-FYI I put the 02 LS6 cam in my whipple charged 6.0 and it didn't pick up at all. That was with no tuning. It only ran for a few days so I didn't have a lot of seat time but now I have it back together WITH tuning, now with ported heads too, and I gained 23 horsepower total. So results may vary but when, not if, I do it again I will go with one of the Comp cams. But here's a fictitous example of my luck: I could remove a nitrous kit from someones truck at the track immediatley after it reduced his times by a full second, put it on my truck and would do good to see 2 tenths! My advice is try it if it is cheap enough, but if you have the $$ go with an aftermarket cam.
Quick Reply: ls6 cam in my truck.
