LS6 Cam setup or Headers
Old 02-23-2010, 01:57 PM
JJB
JJB's Avatar
ls6 is a dog down low in a 5.3 truck no low end ...yo have to wrap it out to make good power ....do a better cam and headers...most people use ls6 valave springs on a lot of cam swaps up to a 555 lift for the 60 bux they cant be beat
Old 02-23-2010, 09:19 PM
The_Rizzle's Avatar
if youre worried about the 02 ls6 cam being too big, you can always do a 98-00 ls1 cam (202/210 .500 117) or the 01 ls6 204/211 .525 116. The ls1 cam is 10 degrees and .030 more lift, so it would help it breathe a little better in the top. Ive heard the 98-00 cam doctors out at 198-208 119.5 so it should pass a sniffer a little easier then the 01 ls6 116. Run ls6 yellows with either. Stock pushrod lengths are ok for both, however, its always good to put a stiffer set in.
However, I would do headers first, and do the cam later.
Old 02-23-2010, 09:32 PM
Silverado53's Avatar
I agree, do headers first no matter what cam you decide to go with.
Is your truck extended cab or regular? What are your goals for the truck?
Check out American Racing Headers.
ARC
57
02-21-2022 10:54 AM
The_W
10-28-2015 09:00 PM
LARRY01Z28
08-01-2015 10:15 PM
Offroadunleashed
07-20-2015 02:25 PM
Aboss
07-09-2015 10:28 AM
Quick Reply: LS6 Cam setup or Headers
