Is this an LS6 Camshaft?
Picked this camshaft up off another member, just trying to double check and validate that it is an 02+ camshaft, and not sure how to go about it. Any assistance?
Great, it doesn't take to much to get a ls6 cam dialed in...very smooth idle and pulls hard 5,500+. Check out this thread. If you can mill your heads .025-.030 that would be optimal for this cam..
This guy didn't do much with his shift points due to the trans being stock, but he still gained decent at the track with stock heads. Again this cam would like a bit more compression if your heads are stock..
LS6 cam swap results - LS1TECH
thompson
12-27-2017 06:48 AM
