LS6 conversion package
Old 11-29-2003 | 02:42 PM
onyx's Avatar
14 Second Truck Club
Default LS6 conversion package
just curious if this would be compatible on my engine... it has GM Performance Parts LS6 "CNC Ported" & Assembled Heads (Hollow Stem Intake & Sodium Filled Lightweight GM LS6 Valves) - GM Head Bolts - GM Head Gaskets - GM LS6 Cam - GM Water Pump Gaskets - GM Timing Chain Front Cover Gasket - GM Timing Chain Cover Crank Seal - GM Crank Bolt GM LS6 Intake - GM LS6 Coolant crossover Pipes and Plugs - GM Valve Cover Gaskets - EGR Block off Kit
would i have to get another water pump? i know that i would have to get rid of the mech. fan since my intake will be moving from where the oem one is....
any comments?
Old 11-29-2003 | 08:00 PM
Flyer's Avatar
The F-body car intake sits to low to put on our trucks. It will hit the water neck on the pump. I don't think the water pump will fit on because of other things. I wonder if it if you had E-fans? As far as the LS6 conversion, it wouldn't apply to our engines since they are different displacements, but of course the cam and the heads will work on there.
I would just go with the head/cam package. Although, if the price is right, you could sell the intake and the water pump and come out on top since the kit includes all the gaskets and bolts you would need.
bearden86
26
11-15-2015 04:58 PM
JordanH
11-06-2015 08:42 PM
Silver8ado
09-30-2015 12:42 PM
JoshH
09-28-2015 12:19 PM
Closer_2001
09-24-2015 10:15 PM
