LS6 intake on 2001 5.3L 1500 2wd?
I know the LS6 intake will bolt up to the engine no problem but is there anything in the way? Accessories, belts, pulleys? Ill have the Intake, Fuel Rails, Throttle body, map sensor and whatever else I may need. Just wanted to know if its possible and what all I should have to do the install.
Has anyone here did this?
Thanks
Mike
Thanks
Mike
You will need e-fans and a waterpump from a T/A or Camaro. The truck waterpump wont work because of the spout coming out of the top of the pump. You will also need to cut you idler pulley off of the acc bracket. Thats just a few. Look up bluecajun5.3 he did a write up on it. And if you have questions he will answer them for you.
SLOPONY
20
10-18-2016 06:05 AM
