LS6 intake on a 4.8L
Here is basiclly everything you need to do it right-
LS6 intake
Idler relocation bracket(www.speartech.com)
You have to trim down the fill neck on your water pump
***97/98 Vette Fuel rail assembly***
Almost forgot you have to switch to E-fans so you also need-
E-fans(LS1,05' truck,FALs)
Nelson Fan Harness or PCM4LESS(I recommended using one of those)
Here is a link to a write up that was done. If you do it make sure you go with the 97/98 Vette fuel rails!
https://ls1tech.com/forums/showthrea...cation+bracket
LS6 intake
