LS6 Intake Swap
Originally Posted by tdrumm
Great post Kano!
Everything looks real nice too. I like your belt routing better than the speartech way. Are you using a stock length belt? Do you have any sketches for the idler bracket and fuel rail adapters? Also what did you do with that massive wire loom that goes over the top of the truck intake?
Can't wait for the results.
I havent measured it out yet but,
the belt will be longer
I dont have any sketches, but I do have guides
to make more for others incase
this works out well
The wire loom is still there
but Im thinking of making another bracket to reroute this
FormerVendor
Fantastic job illustrating the conversion Billy!
If I didn't have so many projects burning at the moment, I'd put together a converison kit. What you did here is great info and will no doubt help many others seeking the most from ther n/a engines.
Cheers ma man..........
Richard
Richard
Thanks for posting the pic of the EVAP module.
Notice you didn't show how far up the crossover sticks up (at least the ones I've seen). Not a pretty sight. If you talk to Nasty Performance they can hook you up with aftermarket rails, crossover, and a fp regulator if you need it. Kind of expensive but looks-wise, definitely the way to go.
I plan to do as you've done to get it all running. After that I'm putting in my order from Nasty.
thanks guys
lets just hope it works as planned
Richard,
Thanks for posting up
finally these heads will be able to breathe up top
I'll call you when I strap it to the dyno or make that next pass down the track
benkey....
I'm with you man
I really want to see how it performs first before I go spending money making it all pretty
what fpr was you planning on using?
aeromotive?
Richard,
benkey....
I'm with you man
aeromotive?
Originally Posted by Kano
benkey....
I'm with you man
aeromotive?
I'm with you man
aeromotive?
Originally Posted by BenKey
I was going to go with whatever Nate @Nasty Performance set me up with. He actually spoke against an Aeromotive. I've never used one, so I don't have any experience with them. I forget what brand he said they were. '04 and above guys don't really have to worry about it since the fp reg is in the tank. At least that's what I understand.
this is the way I understand it also
this would make it somewhat simple for those guys thats returnless...
just change the plug ins and run a fbod fuel rails and injectors
Ive never dealt with aeromotive either
keep us UTD on how this goes
I may be real interested soon
