Ls6 intake swap problems, or not.
I put my truck in the body shop after my ls6 intake swap and now that I have it back problems are surfacing. My wideband was going to 18.5 on idle so I removed the intake and made sure all gaskets were good. I found that I had pinched the old style coolant crossover tubes and intake wasn't seating right. Then I installed the new style crossovers and reinstalled the intake. I took it for a spin and at WOT my O2s are reading 890 mv but wideband reads the word lean. At idle fuel trims fuel trims are in the negative 2-4s so I assume its taking away fuel but wideband reads 18-19. Does this sound like a lean condition or just a messed up wideband sensor. I'm thinking the sensor because it should at least show a # at wot since it feels powerfull and there is no sign of a problem.
i found a place to get the Wideband 02 sensors for cheap!
they are Bosch.. im not at home so i cant get you the PN... but i think DC_justin found them on Amazon for cheap.
GrooveCityZ71
08-31-2015 12:05 PM
iregret
07-27-2015 10:32 PM
