ls6 into silverado help??
Old 03-24-2012, 09:17 PM
TXSZ66AVLANCHE's Avatar
The power difference for the truck vs vette intake is minimal, however the truck intake will make more torque. The vette coils have zero advantage.
Old 03-24-2012, 09:21 PM
Registered User
jinxd12's Avatar
i didnt mean the coils i meant the injectors...has to have an advantage...if it has to be tuned might as well tune it to where i get the most power. is there a tuner out there like a plug and play where i can do it all myself...or does it need to be dyno tuned?
Old 03-25-2012, 12:10 AM
Bad Boyz Racing's Avatar
I put a 04 Z06 LS6 in my 99 ecsb. You'll need a Speartech idler pulley relocation bracket about $85.00, I used a water pump for a 07 NNBS think part # 12600767 about $150.00, it cleared my dirve by cable TB and a top raditaor hose off an 07 NNBS part # 19130027 about $52.00. I used the stock fuel rails off a 04 Z06, and an aftermarket fuel pressure regulator with a return line and 42lb car style injectors and installed car style injector plugs in to my wiring harness. Installed a set of Dynatech SuperMaxx #115-841300, 1-7/8" headers. While i had the motor out i pulled my wiring harness out and shortened and lengthened all the connectors so i could route it around the back of the motor much cleaner install. Installed a set of electric fans off an f-body with a nelson wiring harness and relays. I tune with EFI Live i had to change my PCM's operating system to a 2002 operating system, i used PCM 12212156 operating system. If you need any advice are part numbers i have a file full of reciepts and notes, i would be more than happy to share. PM me and i'll give you my number. Good Luck.
Here's a picture with the water pump, fuel rails and injectors installed.
My cam was speced by Patrick G, Guerra Motorsports cam, 224/228 .609"/.588" 110LSA + 2 advanced cam for my LS6
Here' the final Install
Now What it looks like
Old 03-25-2012, 01:22 AM
lady3bglover's Avatar
Nice score!!
Old 04-15-2021, 09:22 PM
Registered User
Nick Visser's Avatar
Default Complete newbie to motor swaps I've done so much research I'm more confused now
So I'm new here and have read this post about 100 times but not 100 percent sure if I fully understand as this is my first time really doing anything like this. I'm putting a 02 z06 motor into a 2003 silverado and I'm stumped at the accessories drive here. I have the ac pump on the frame rail the alternator from Corvette won't fit the truck bracket the wire going to truck alternator is different plug corvette 4 wire truck 2 wire I have plenty of access to junk yard parts any info is greatly appreciated. I am looking to get this running asap and can't go anyfurther until I figure this out.
Old 04-16-2021, 09:38 AM
makes children cry
_zebra's Avatar
i'd personally reuse the truck accessories & brackets on the LS6
Old 04-16-2021, 10:30 AM
Jeff71's Avatar
Nick, if you are using the car intake manifold and a drive by cable throttle body, you are probably going to need the water pump and for sure going to need an idler relocation bracket that bad boyz racing mentioned in post #13. The reason is, the car manifold is much lower profile than the truck version so you need to move the upper radiator hose and accessory drive belt out of the way for it to fit. Other than that, the truck ac bracket and compressor along with the truck ps pump, alternator and bracket should be reused.
Old 04-16-2021, 10:47 AM
makes children cry
_zebra's Avatar
03 silverado & LS vettes all used electronic TBs
Old 04-17-2021, 05:01 AM
adriver's Avatar
Start a new thread. I'm sure you will have plenty of questions about it along the way, and it will be better for everyone to follow YOUR thread. OP was only here long enough to make this thread, and I think it was BS from the start.
Old 05-06-2021, 04:55 AM
Registered User
Jonathon Blakely's Avatar
Default Seeing what this all about.and to say . I laughed!
ZAPP59
02-09-2007 05:23 PM
ster
17
10-25-2006 12:03 AM
Slapchuck
08-02-2006 02:30 AM
piratebaseball
16
07-10-2005 12:57 PM
stroked 4.8L
01-20-2005 10:00 AM
Quick Reply: ls6 into silverado help??
