LS7 Rocker Arms
#22
Originally Posted by tdrumm
The duration of the cam is unaffected, but the valve duration is increased.
Increasing(or decreasing) rocker arm ratio by 0.1:1 will increase or decrease the duration by 2 degrees.
example:
GM Hotcam(LT4)
0.525"/0.525" 218/228 duration 112 LSA with 1.6:1 rocker arms
0.500"/0.500" 216/226 duration 112 LSA with 1.5:1 rocker arms
peace
Hog
#25
sweet so has anybody use the ls7 springs on anything will they fit i read in hot i think that they were good to some pretty high lift in the mid .600's i think but they had to replace the retainers i think it was so the spring sat a little higher and reduce coil bind other than that they were goods stuff just need to know if they will fit our heads.then for like 250 you could have a good spring and rocker upgrade.
#28
Originally Posted by TURBO8
I was wondering would your pushrod size change?
