LS7 Rocker Arms
Old 02-04-2006, 07:30 AM
  #21
tdrumm's Avatar
Originally Posted by 4.8T
does the ration affect duration or just lift?
The duration of the cam is unaffected, but the valve duration is increased.
Old 02-04-2006, 04:43 PM
  #22
hog
hog's Avatar
Right on, valve duration is affected by rocker arm ratio, just like valve lift.
Increasing(or decreasing) rocker arm ratio by 0.1:1 will increase or decrease the duration by 2 degrees.
example:
GM Hotcam(LT4)
0.525"/0.525" 218/228 duration 112 LSA with 1.6:1 rocker arms
0.500"/0.500" 216/226 duration 112 LSA with 1.5:1 rocker arms
peace
Hog
Old 02-04-2006, 06:38 PM
  #23
TURBHOE's Avatar
so if i take my lift and divide it by 1.7 and multiply by 1.8 that will give me my new lift and then just add 2 to the duration. is this correct?
Old 02-05-2006, 01:23 AM
  #24
hog
hog's Avatar
As long as 1.7:1 is the original ratio of the rockers, then yes.
peace
Hog
Old 02-05-2006, 08:31 AM
  #25
TURBHOE's Avatar
sweet so has anybody use the ls7 springs on anything will they fit i read in hot i think that they were good to some pretty high lift in the mid .600's i think but they had to replace the retainers i think it was so the spring sat a little higher and reduce coil bind other than that they were goods stuff just need to know if they will fit our heads.then for like 250 you could have a good spring and rocker upgrade.
Old 02-05-2006, 09:26 AM
  #26
8 Second Club
samdogmx's Avatar
so has anybody ran these yet? I really want to get some more lift outa my little cam. Do these work OK?
Old 02-06-2006, 02:06 AM
  #27
TURBO8's Avatar
I was wondering would your pushrod size change?
Old 02-06-2006, 11:09 AM
  #28
SS_bnoon_SS's Avatar
It *shouldn't*, but as with any cam, head, or rocker arm change you will have to check your own combination before final assembly.
Old 02-06-2006, 06:50 PM
  #29
TURBHOE's Avatar
so what about these valve springs will they work is any one gonna try'em if i knew there was a very good chance i would do it but i still have a d-max intercooler in my garage that i have to custom fit because it was beleived to be a drop in job and wasn't
Old 02-09-2006, 05:18 AM
  #30
8 Second Club
samdogmx's Avatar
nobody using these rockers yet? Im gona order some, guess i'll be the first to try them out?
Quick Reply: LS7 Rocker Arms
