LS7 Rocker Arms
Old 02-18-2006, 10:10 AM
  #41
8 Second Club
samdogmx's Avatar
i got mine friday, i mounted two of them & they bolt up, but the tip sits pretty far back on the top of the valve compared to the stockers. I did the wipe test putting marker on the valve & its pretty far off center. So i duno if they are gona work?
Old 02-18-2006, 10:24 AM
  #42
Got any comparo pics?
Old 02-18-2006, 01:59 PM
  #43
PT's Slowest Truck
budhayes3's Avatar
I guess that a different length pushrod wouldn't make any difference huh...I'm thinking that the LS7 rocker may be longer from the fulcrum to the tip? Pics would be cool if possible...
Old 02-18-2006, 02:27 PM
  #44
hog
hog's Avatar
Or it might be shorter from the pushrod side to the fulcrum, thats how most higher ratio rockers increase the ratio.
This is why you have to drill out the pushrod holes on the iron L31 Vortec 350 heads when going from 1.5:1 rockers to 1.6:1 rockers or the pushrod will rub on the head.
peace
Hog
Old 02-18-2006, 11:37 PM
  #45
8 Second Club
samdogmx's Avatar
stock on the right 1.8 on the left
it looks to me that they are the same from the fulcrum to the pushrod, but longer from the tip to the fulcrum.
Its hard to see in the pic but this is the valve stems, the arrrow is were the shiny spot was.
only solution i could think of was possible taking the rocker stand & milling it down shorter. (would also require shorter pushrods i assume) But i dont know if that would work or might. What are your guys thoughts?
Old 02-18-2006, 11:48 PM
  #46
How much was this costing you compared to going to a set of Crane or Comp 1.8s that didn't require any special milling? Just curious. Milling the rocker stand may cause a geometry issue and maybe even cause binding. Personally, I'm no so sure I'd feel too good about pioneering this mod. I'm not smart enough on the implications of changes any milling/shimming, or whatever is needed would cause. I'm sure someone will figure it all out though.
Old 02-19-2006, 12:14 AM
  #47
hirdlej's Avatar
I don't see a problem with the new rockers. Someone correct me if you think I'm wrong, but as long as the rocker (when fully torqued down) sweeps across the entire top of the valve, it should be ok. My roller rockers on my big block chevy sweep back and forth across the top of the valve and this is normal action. With the extended travel of the 1.8 rocker ratio, it may need to sweep further back and forth across the top of the valve stem. I reillustrated your picture to show what I mean. if the full sweep remains inbetween the red lines, I would run it. If it goes where I painted it black, it'll need to have modification to the installed height along with a different length pushrod.
Old 02-19-2006, 10:43 AM
  #48
PT's Slowest Truck
budhayes3's Avatar
From the pics, it looks like the LS7 rocker is contacting right outside the red lines illustrated, not the center of the valve, but the edge.
Old 02-19-2006, 03:42 PM
  #49
8 Second Club
samdogmx's Avatar
correct, its only hitting the outer edge of the valve, not the center.
Old 02-19-2006, 05:58 PM
  #50
How much was a set of these things?
Quick Reply: LS7 Rocker Arms
