LS7 Rocker Arms
#61
8 Second Club
Originally Posted by SS_bnoon_SS
Only the intake valve is offset, not the exhaust side. Try again. My guess is that samdogmx did not mock them up with long enough pushrods and/or shims to move the swept area onto the correct portion of the valve stem.
BTW has any of you other guys that orderd these got them yet?
#62
Originally Posted by samdogmx
can you explain to me how longer pushrods will make the tip of the rocker contact the valve at a different location while the fulcrum is still remaining in the same location? Im not giving up on these yet, but I dont know what to do to move the contact point.
#63
Originally Posted by mjhoward
You can move the actual contact point with the valve slightly with a different length pushrod if you have fully adjustable rockers. You actually change the height of the fulcrum. The LS7 rockers arn't fully adjustable thus that theory won't work.
BTW, Yelo, it doesn't matter about the valve angle. The short side of these rockers are the same length as stock. The only way to make a 1.8 rocker fit these engines is either to build one with a shorter-short side and make the long side about the same as stock, or to slightly change the geometry with shims and/or longer pushrods to change the attack angle on the valve stem. I'm sorry if my info on the intake/exhaust angle was incorrect, but it's a mute point anyway...
#64
It certainly will, it just requires shims. Adjusting rocker swept area on the valve stem is not uncharted territory.
#65
I guess I should have been more clear. I don't know for sure of course, but the amount of shims it looks like it will need would require a longer rocker bolt and the shim, unless custom machined, could cause instability.
And, the valve angle is NOT a moot point here...the whole 2nd half of this thread is about why these rockers aren't contacting the valve at the correct location !!!, While there ARE ways to make these work (shimming and longer pushrods) the fundamental reason behind why they don't just drop in is because of the revised valve geometry.
#66
Usually with aftermarket heads, when they change the valve angle they change the rocker mount as well. For reasons we do not know, GM engineers decided to change the rocker instead of the rocker location. Sucks.
#68
Try stacking .010" shims until you get to the proper alignment. You *may* end up with the rocker tip at an out of spec angle to the valve-tip if you have to shim too far though, it shouldn't be too far out of whack though.
You'll have to get an adjustable pushrod to measure what pushrod length you need though......
#69
#70
So a 15 degree valve angle 1.8 rocker would be different somehow? Riiiiiiiiiiiiiiight...
We are trying to make parts that were designed for a DIFFERENT ENGINE SERIES work on our motors......yes, there is enough similarity that parts LOOK the same, but NO-ONE knows whether or not they will FUNCTION the same until it gets tried.
If you refuse to agree with me that's your choice......but insulting my intelligence and being derogatory towards me in your posts is NOT the way to prove to me or anyone else that you're right, all that does is reduce my respect for you............
