LS7 Springs?
Old 02-09-2006 | 11:30 PM
budhayes3's Avatar
PT's Slowest Truck
Default LS7 Springs?
OK, we have a few guys doing some research to find out if the LS7 exhaust rocker, which has a 1.8 ratio, will work on our engines (4.8, 5.3, 5.7, 6.0 etc.). There's a thread about it here: https://www.performancetrucks.net/fo...d.php?t=356657
4.8T came up with a good question in that thread, what about the LS7 springs? He mentioned that they're supposed to be good up to .600 lift...will they work in our engines as a budget spring upgrade? Are they the same height, diameter, etc?
It's nice to be able to do performance upgrades using factory parts and saving a few bucks in the process
Old 02-10-2006 | 12:29 AM
ap2002's Avatar
im really interested on this also, I hope some one comes up with some good results...
Old 02-10-2006 | 06:38 AM
tdrumm's Avatar
LS7 valve spring p/n 12578457
I asked over on tech, hopefully someone will chime in over there.
Old 02-10-2006 | 05:59 PM
TURBHOE's Avatar
i was reading my hotrod or something mag i forget which one but they put in a cam in the ls7 that was running like 620 or more lift something crazy and they used stock springs but use diffrent retainer i think it said to allow the spring to expand a little more and that was all it needed. i'll reread and see exact numbers.
Old 02-11-2006 | 08:37 AM
TURBHOE's Avatar
https://ls1tech.com/forums/showthrea...ght=ls7+spring
a few guys replied and they confirmed what i read it was like .630 lift and they had different retainers to do it. but the stock cam is at like .591.
Old 02-11-2006 | 11:49 AM
budhayes3's Avatar
PT's Slowest Truck
Any info on the seat pressure of these springs? Sounds like they'll work with special retainers...
Old 02-12-2006 | 04:07 PM
vettenuts's Avatar
Just be careful, a few have failed on the Z06 and motors have had to be replaced. Not sure what the problem was, but you may want to check the LS7 section of LS1tech.com before buying.
Texas5.3_1251
03-05-2016 08:10 PM
1989k1500
11-02-2015 05:16 AM
SlvrSierra4.8
10-01-2015 09:39 PM
OHsixLS3
09-25-2015 11:20 AM
LT-1 SS
09-03-2015 10:24 AM
Quick Reply: LS7 Springs?
