LS9 cam into a 4.8, what parts do i need?
i know this topic has been beat to death, and i've been using the search function here for the better part of 3 hours.
I just want a list of part #'s needed to swap the LS9 blower cam into my 4.8.
i know i need the front cover, the cam sensor, and a cam sprocket (1 bolt or 3 bolt?)
anything im missing, other than the part numbers?
note: this is not going in my truck, i have a 87 regal t-type i'm putting a 4.8 in, and i'm going to boost it.
you goin to put a blower on it or turbo?
The newer stuff is 1 bolt.. the older stuff is the 3 bolt cams.
Send Beau an email, he can fix you up with PNs and get you a quote..
BNovak@scoggindickey.com
Trucks Sponsor
LS9 is the exception to the rule and uses a 3 bolt camshaft. I assume your 4.8 is a 24x. If so, you will need a LS2 Front Cover Kit, Cam Sensor Extension Harness, & a LS2 Timing Set. I keep everything in stock! Call me or e-mail me Tuesday and I'll get you fixed up!
Suburban2500
07-19-2015 04:50 PM
