LS9 Cam in an LQ4
Old 09-30-2014 | 12:34 AM
LQ4 Tank's Avatar
Default LS9 Cam in an LQ4
Has anyone here messed around with swapping an LS9 cam into their trucks, specifically an LQ4? I can get one cheap off of my tuner that came out of a brand new ZR1 and am wondering if it's worth it. Looking at spec.'s it seems to be the best LS stock cam, but I'm not too experienced with cam spec.'s so mayber it's horrible, haha, just wanting some input!
Old 09-30-2014 | 01:00 AM
Vortec350ss's Avatar
It'll really make your bottom end soft and love rpm. Not sure it's a good idea for you.
Old 09-30-2014 | 01:11 AM
LQ4 Tank's Avatar
Heck I'd really hate to hurt what little bit of bottom-end power it has now, just don't wanna spend a ton on a name brand cam when I can get a GM cam for cheap.
Old 09-30-2014 | 01:16 AM
The cam to look for that will give you the best compromise is the LS2 cam that has the cam sensor stuff on the back still. Those have shown to make the most power in a LM7 5.3 from top to bottom out of all the factory cams. That would likely give you the most power under the curve.
Other than that look for something like a used comp 212/218. Despite it's larger specs compared to factory cams it's advance really makes it shine down low and it's mid range compared to the factory stuff.
Old 09-30-2014 | 01:22 AM
LQ4 Tank's Avatar
Either of these work good when my forced induction comes along (Leaning towards F1 but maybe a turbo just for giggles), or would I be better off going with a custom grind cam when the forced induction comes along? Sorry for all the questions! Gotta learn somewhere.
Old 10-05-2014 | 08:07 AM
D3N4L1's Avatar
I put on on my 6.2 truck. Bottom end sucked. Top end was great. With a stall the ls9 cam will be good. Otherwise get another cam
Old 10-05-2014 | 10:30 AM
brewster240's Avatar
there is no ls2 cam with the cam sensor on the back. you are thinking of ls6 cam.
Old 10-05-2014 | 10:56 PM
Beatdown Z's Avatar
Laid Back
Think about what the LS9 cam was designed for...
Old 10-06-2014 | 12:34 AM
LQ4 Tank's Avatar
Yes I know, just wanted some real-world proof with a swap. Everyone over on LS1Tech loves it so pretty set on getting it. I see dollar signs mainly.
Old 10-06-2014 | 12:56 AM
oakley6575's Avatar
Sounds like you are set on it so not sure what the point of this thread is. These guys are right.. It is designed for a 3400lb car that is supercharged (doesn't need any bottom end power) and that is designed to be revv'd to the moon. Those are all the total opposites that we want in our trucks. We need low end torque, and something that stops making power in the 6000-6400rpm range.
I'd much rather run the LS6 cam in your combo than the LS9. But like e v e r y o n e has said here, there are much better options. Keep an eye on the classified section and the buy sell trade page on facebook and you'll be able to find a 212/218 or triple 12 for what you can buy the LS9 cam for.
