lsx 376???
Old 03-16-2014 | 04:21 PM
javier4.8's Avatar
Default lsx 376???
Anyone in here running the lsx 376 crate motor and boosting it. Wondering if it is.worth it and how much boost it's rated for
Old 03-16-2014 | 06:38 PM
1Bear's Avatar
It depends on which of the LSX376 engines you’re looking at as to what they are rated for and what they can handle. I’m sure either of them can truly handle quite a bit more than what they are rated at, but for a comfortable baseline, I’m sure they had to start somewhere and with a number they were comfortable with only a 87 octane requirement.
The LSX376-B8 (19260831) adds 9.0:1 forged pistons to an otherwise stock rotating assembly in a LSX iron block with stock LS3 heads and camshaft, and is designed for mild-boost applications up to about 8lbs.
The LSX376-B15 (19299306) is equipped with 9.0:1 forged pistons, forged rods and 8-bolt LSA style forged steel crankshaft in a LSX iron block with LSX 6-bolt LS3 style heads and a little more aggressive camshaft, and is designed for boost applications up to around 15lbs.
Old 03-18-2014 | 12:14 PM
Blackpanther99's Avatar
Those engines love boost depending on setup.
TrendSetter
11-26-2018 08:18 AM
Three6GMC
10-27-2015 09:04 PM
racedad70
09-16-2015 02:51 PM
omc8
08-10-2015 11:39 PM
