the LSX block
Old 03-01-2007, 01:42 PM
Default the LSX block
Id really like to do this build... and well since I cant get on the list for the block now I figured id gather as much information as possible. Beside the block what am I lookin at purchasing, head wise? What going to fit, Id love to have 600hp n/a around, and thinkin a 454 small block will be sufficient to give me room to play later on. Any info on doing this will help, tia guys
Old 03-01-2007, 01:52 PM
99/5.3w/hips's Avatar
I think Mark(2004Denali) is working on this build and slowly gathering pieces.
Old 03-01-2007, 01:53 PM
zippy's Avatar
The part number is 19166454. Current list on it is 2500.00. Dealer cost is 1750.00. Wholesale/trade is 2125.00.
Old 03-01-2007, 01:55 PM
white1's Avatar
Id go with the L92 heads
Old 03-01-2007, 01:56 PM
ok so l92 heads would be the most sufficient? i know how much it cost and all that, im just lookin for best build, what will i have to rewire, cam specs, anything in particular different then when i did my 6.0 swap basically.
Old 03-01-2007, 01:58 PM
zippy's Avatar
I'd look into LS7 heads and intake with a bore that big.
Old 03-01-2007, 02:05 PM
what about the factory ls7 intake? could that even be adapted?
or what do u suggest?
Old 03-01-2007, 05:09 PM
Bill Reid's Avatar
I would get more info on the LS7 based LSX 6-Bolt heads, including when they will be available, prior to purchasing any heads. I wouldn't worry about cam specs until you have the rotating assembly in hand... as in committed to how big the motor will be. With an expectation of 600 N/A crank (or rear wheel for that matter) I would also be thinking about how much you will budget to fortify the rest of the drivetrain. Just some thoughts
Bill
Old 03-01-2007, 05:24 PM
14bolt is goin in the rear most likely unless I decide on a ford 9" and a 4l80e, but right now i dont want to put it on a budget, but I dont want to spend as much as I can either... lets say like 8000 or less for complete motor itself, see what I can do that. What is the news of the release for those...
Old 03-01-2007, 07:08 PM
02_2500avalanche's Avatar
Hey GMRacer, you go to school with my buddy jeremy at fitchburg dont you? hes told me about your truck and i was like hey i know that truck from performancetrucks.net lol
Alex
Quick Reply: the LSX block
