the LSX block
Old 03-02-2007, 11:02 PM
  #21
Fast lane preferred
meatwad's Avatar
Originally Posted by 2004Denali
Yes I am going to do a LSX Build. Just waiting for the Block to come out so I can start ordering parts.
Mark
Make sure you keep us updated. I am considering this build as well, cash permiting. There was mention on tech that GMPP may offer a crate based on the lsx block. May be this summer before I decide exactly what I want to do.
this is about Reggie Jackson's LSX powered carbuerated 454
The bottom end of the engine uses a Lunati rotating assembly with forged parts and Mahle pistons that combine with the LSX heads to deliver a pump-gas-friendly 11:1 compression ratio. A custom-grind camshaft was sourced and Comp Cams supplied the remainder of the valvetrain components.
At Warren Johnson's dynamometer facility, the LSX engine produced 641 horsepower and 611 lb.-ft. of torque. More than the peak numbers, however, is the engine's Kansas-flat power band. The engine makes 520 lb.-ft. of torque at only 3,000 rpm, with torque rising steadily throughout the rev range.
calsdad
06-14-2023 11:07 PM
gmcyukon
10-05-2015 06:20 AM
Mark_k
10-01-2015 11:17 PM
old motorhead
09-29-2015 08:22 PM
trevorh1
09-27-2015 08:47 PM
Quick Reply: the LSX block
