LT1 OR LS1 FANS??
Old 01-22-2003, 01:12 PM
ranwalk's Avatar
Default LT1 OR LS1 FANS??
Which one is a direct fit for our trucks???
Old 01-22-2003, 01:39 PM
YellowChevy4.8's Avatar
Default Re: LT1 OR LS1 FANS??
I think its the LS1 fans..but one of these other pros could verify that....
Old 01-22-2003, 01:43 PM
GREGGO's Avatar
They are the same except the LT1 fans have slots cut out in the piece that holds the fans. Personally, I like the LT1's better because I believe it allows more flow through the radiator, but that's just my opinion. But either will fit, you just have to make your own mounting kit.
Old 01-22-2003, 02:28 PM
ranwalk's Avatar
Thanks for the responses.Seems like the best way to go for the price.I'm gonna start looking and see if i can find some.I like anything that will free up some hp and doesnt require any tuning. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
Old 01-22-2003, 02:29 PM
BigKID's Avatar
Umm... that is what I was going to say... <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old 01-22-2003, 02:39 PM
ranwalk's Avatar
Hey Kenny....how are yours wired??Do they operate like factory fans??Turn on and off by themselves,or do you have them on a manual switch..or combo of both?
Old 01-22-2003, 03:06 PM
ArticGMC's Avatar
Where is everyone getting their ignition power for their fans under the hood? I have mine wired under the dash and I want to relocate that wire to under the hood.
Lar
Old 01-22-2003, 03:07 PM
I installed some LT1 fans about a month ago, it was pretty straight forward. I got the fans off of E-bay and the wiring relay from Kragans. The fans were 103$ shipped and the relay was about $35. I also put all the wiring in the black wiring jackets to make it look factory, looks pretty good. I have both fans set up to come on at about 195*, I used an infra-red heat gun we have at work and just let the truck idle unitl the fans came on at the temp I wanted. The fans have only come on about 3-4 times since I've had them, each time it was about 70* and I was sitting at a stop light for a while. They only run for about minute then go off. They fit in the lower radiator support and I made up two brackets to support the top. You can use the bolt and bolt holes that are used to hold the top part of the shroud in place. Hope this helps!
Jim
Old 01-22-2003, 03:16 PM
BigKID's Avatar
I did have mine wired up to a thermo switch and a manual switch but I used the manual switch for my N2O since it was already there. I have a schematic but I dont think I have it swapped to my new page yet. I will find it and put it up for you guys.
Old 01-22-2003, 03:23 PM
BigKID's Avatar
Ok guys here it is:
www.dive-n-drive.com/miscpics/FanSchematic.jpg
and to clear up some abrivations: LFB = left fuse box, in cab, side of dash. UFB = underhood fuse box, driver side.
Quick Reply: LT1 OR LS1 FANS??
