lt's and low end loss
#73
Yeah, I'm gonna pick up a couple flowmasters I think. If I dump the exhaust at the rearend, would it be loud in the cab. Right now I have the exhaust going out the side in front of the passenger tire, but don't think I have room for mufflers and going out the side.
#74
Yup, the voltage should constantly fluctuate from around 100 mV , high oxygen content = lean mixture, to 900 mV , low oxygen content = rich mixture, during closed loop operation. Look to see if you got a steady high or low voltage, in closed loop, or a inactive signal like a steady 450 mV. It shouldn't be steady in closed loop.. I also believe the heater circuit is straight up 12v.
#75
Like he said, if you do see that one of the O2's is reading a steady voltage after warmup you probably have a bad sensor. Wait until the engine warms up to start looking at the O2 readouts.
#76
The O2 that was bad in that 2002 truck would only max to about 550, but would still switch. The O2's still switch in OL too btw.
#78
for what it's worth i also had a o2 sensor goin out on my 00"rcsb and it was causing some decent low end power loss as well. changed it and she ran a 13.7@99 with just bolt ons and some 4.10's.
#79
