View Poll Results: which looks better for the 6.0 LQ9
Lunati Voodoo 217/223 .549/.549 113LSA cam
![](https://www.performancetrucks.net/forums/images/polls/bar2-l.gif)
![](https://www.performancetrucks.net/forums/images/polls/bar2.gif)
![](https://www.performancetrucks.net/forums/images/polls/bar2-r.gif)
![](https://www.performancetrucks.net/forums/clear.gif)
47.06%
VHP "trucker" 216/224 .551/.551 115 LSA cam
![](https://www.performancetrucks.net/forums/images/polls/bar3-l.gif)
![](https://www.performancetrucks.net/forums/images/polls/bar3.gif)
![](https://www.performancetrucks.net/forums/images/polls/bar3-r.gif)
52.94%
Voters: 17. You may not vote on this poll
Lunati voodoo 217/223 vs VHP "trucker" 216/224
I recently discovered this lunati cam and i cant seem to get the skull with the cam crossbones out of my head
the 2 cams are pretty similar no?
Voodoo Cam
# Advertised Duration (Int/Exh): 267/273
# Duration @ .050 (Int/Exh): 217/223
# Gross Valve Lift (Int/Exh): .549"/.549"
# LSA/ICL: 113/109
# Valve Lash (Int/Exh): Hyd/Hyd
# RPM Range: 1800-6400
Trucker cam
DUR @ .004" 278*/ 286*
DUR @ .050" 216*/ 224*
* LIFT .551/.551
OVERLAP 53*
LSA 115*
POWER RANGE 2000 TO 6200
which do you like better for a 6.0Lq9? with 2600 stall?
Voodoo Cam
# LSA/ICL: 113/109
Trucker cam
* LIFT .551/.551
OVERLAP 53*
LSA 115*
11 Second Hall Moniter
Where did you find a VHP trucker cam available?
Anyways, I think the Voodoo cam will lope more, and will run strong in a N/A 6.0
However, the trucker cam WILL give you alot of torque N/A, and if you ever decide to go F/I, you can keep the trucker. It has been proven to work well N/A or F/I. Not many cams can do that.
PT's Slowest Truck
The specs are similar, but I'm sure that the lobe designs and valve events are different. Both cams seem like they would make good torque and pull to the advertised RPM's. The Lunati should lope slightly more, but neither of them will be really lopey in a 6.0 if properly tuned. I went with the Vinci Trucker myself, which is currently sitting in the box under my bed
![Winky](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_wink.gif)
The specs are similar, but I'm sure that the lobe designs and valve events are different. Both cams seem like they would make good torque and pull to the advertised RPM's. The Lunati should lope slightly more, but neither of them will be really lopey in a 6.0 if properly tuned. I went with the Vinci Trucker myself, which is currently sitting in the box under my bed ![Winky](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_wink.gif)
VHP is selling trucker cams
i phoned em 2 months ago
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
also take a look at this from lunati i was thinking this could compliment the voodoo nicely
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
http://www.lunatipower.com/Product.aspx?id=2584&gid=322
is this too much spring for a stock head
PT's Slowest Truck
i phoned em 2 months ago![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
also take a look at this from lunati i was thinking this could compliment the voodoo nicely![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
Crane was bought a few months ago, (I believe the company that bought them is S&S Cycles IIRC), so it's possible that they may be turning cams out again. When I bought my Trucker cam Roger Vinci told me that he only had one or two left at the time, (I think I got the cam this summer? no more than 6 monts ago), so I'm not sure if you got one of the few that he had left or if they're grinding new ones.
