MAF lbs/min conversion to hp
What is the formula again?
I'm pulling 57.71 on a regular basis with 55'ish outside temps. What would that equate to in hp?
I'm seeing 1.05-1.07 g/sec too. Wonder what a pulley change will get me?
I think its 9.8 or something real close to 10 times the lb/min number=flywheel hp. So its probably real close to 570 fwhp. Then I think you have to subtract whatever it takes to run the blower. Probably 50 hp or so?
Do you mean 1.05-1.07 g/cyl?
How many psi are you seeing?
59.9lb/min is the most you will see on the stock maf, or 454gm/s. The PCM is capable of reading 512gm/s, but requires a rescaling of the maf tables in edit. I hit 59.9lb/min very easily and do it regularly with 10lbs of boost. I have not tried to alter my maf tables yet, though.
Originally Posted by BenKey
From what I understand, the stock maf will do, just need to redo your tables in edit in order for your PCM to read beyond that number.
BTW I got your mail... Experienced? Say good bye to your trans
lucas287
31
01-12-2021 06:18 AM
air, airflow, calculator, conversion, convert, converting, flow, gs, gsec, hp, lbm, lbmin, maf, mass, units
